DT-LV LINK uSING tRIGGER OPTIONS?
I am currently trying to create a trigger option with my LabView Program. I have a DT-9840 A/D Board. I made few minor modications to a simple continuous acquisition.vi that was downloaded from the Data Translation, Inc website.  Attached is my lab view code. Everytime i try to specify different criterion other than the default given by the Data Translation developers . I receive an error about the DT AI Read.vi ...the trigger specifications code is in the DT AI Start moduel. I was wondering if anyone can help or steer me in the correct direction. Thanks for your time and considerations.
(2,668 Views)
Schola,
You may want to try to get in touch with Data Translation and see if they can provide you with any insight as to what is happening here.
The VIs you have posted rely on having certain Data Translation written llb files which I don't have so I am unable to see how they were intended to work.  Perhaps another member of the community has used these VIs before and can offer some guidance?
Best of luck getting this up and running,
Simon H
(2,653 Views)
