DTMF generation with NI SPEEDY 33
I have compiled a block diagram for DTMF generation, but when running the VI on the SPEEDY 33 DSP the tones sound incorrect. I am looking for some advice on what to change in order to make the tones sound correct. My VI is attached.
Thank you
-kiz.
(3,551 Views)
In what way don't they sound correct?  Too high pitched, too low pitched, crackly, too quiet, too loud, ......?
(3,547 Views)
Too high pitch? That may be the best way to describe the generated tone.
(3,543 Views)
I have attached a wav illustrating my generated tones from the SPEEDY 33.
Thank you.
-kiz
(3,514 Views)
Accepted by topic author killakiz
Kiz-
Does your SPEEDY 33 work correctly when running the “Sine Generator” example from the Example Finder (only available in LabVIEW 8.6 or below)?
Does your code work correctly with a different SPEEDY 33?
Mike S
NI AE
(3,489 Views)
Thanks, after reviewing the sine generator example I noticed that the Fs on the Analog Output was set way too high.
Thank you.
-kiz
Message Edited by killakiz on 11-25-2009 08:43 PM
(3,471 Views)
