DTMF generator
It's kind of annoying to repeat the same answer over and over again. With an USB-6008, you can only use the DAQmx-Write-> 1 Sample selections. No waveform, no 2D-Array. With one channel just 1 numeric.
A USB-6211 on the other side is capable to run your programm from your first message...
Regards, Jens
Kudos are welcome...
Message 11 of 14
(1,008 Views)
Hi Gerdw,
         I've connected using usb 6211 and i can generate a DTMF tone and another thing is i have connected the output with the HT9170 DTMF receiver and i tested using that decode it gives exact signal what i want, now what i want is i need to auto generate a tone with some delay in ms, i have attached you a code so that you could understand and i have used time delay function to give a delay between each tone but it not affecting the output.
Thank you,
Paul
Message 12 of 14
(991 Views)
Hi Paul,
What about a state machine approach? Or a queue-driven state machine?
It would be very easy to handle things like "automated state changes"!
(Easiest would be to use a FOR loop to dial an array of numbers…)
Message 13 of 14
(989 Views)
Hi Gredw,
   Thanks a lot for your reply, by the way i got what i want.
regards,
paul
Message 14 of 14
(979 Views)
