DVR Parallel Read Access
In LabVIEW 2017 there is a new DVR option, Parallel Read Access. In this mode...
When the border node on the right is unwired, LabVIEW allows multiple, concurrent read-only operations and does not modify the data value reference.
I was wondering whether anybody has tested this mode for speed. In some VIs, sorry I cannot post them, it appears slower while in others faster. I am not sure when to use this mode. For me, it seems any read only operation should be better in this mode (even just a single access), however, in my testing this is not the case.
Anybody else out there test this new feature and can offer some thoughts?
mcduff
(7,246 Views)
Could you post an example code of this?
Regards!
(7,183 Views)
I can't post my application due to company policy, but something similar to the diagram below.
(7,179 Views)
I ran the code below and saw pretty comparable results between the read only and the read/write.
Let me know if you see much difference in speed with the above
(7,163 Views)
Maybe my example was bad. For this other case I can describe and show some code. I am downloading millions of points from a DAQ device, before plotting the data I do a Min/Max type of decimation so I plot a few thousand points instead of a few million. Below is the outer VI
The array is not being modified at all in this case, just read.
The subVI inside the in-place structure looks like this
Maybe its slower because I'm reading chunks of the array, not really sure. I do know if I put High Precision timers on the outside of the loop it is faster without the Read Only mode.
Thanks for looking into this.
mcduff
(7,156 Views)
Am I missing something here?  Does this not work for Classes in DVRs?
(6,839 Views)
The read-only feature does not work with classes in 2017 although this is a bug. CAR 671221 was filed to address this.
(6,831 Views)
