Dani starter kit2.0
I had a problem with Dani robotics starterkit2.0.The problem was I build a VI on starterkit and click run as startup it works correctly and later I wrote another VI and build that on starterkit and click run as startup the kit works properly at first time after that when I off the master switch and then on it the kit working for first VI instead of second VI and again off-on the master switch it giving the second VI as output.
(3,943 Views)
I had a problem with Dani robotics starterkit2.0.The problem was I build a VI on starterkit and click run as startup it works correctly and later I wrote another VI and build that on starterkit and click run as startup the kit works properly at first time after that when I off the master switch and then on it the kit working for first VI instead of second VI and again off-on the master switch it giving the second VI as output.It gives the alternate VI as output instead of one of the VI's as output.
(3,938 Views)
Please don't create duplicate threads on the very same topic!
I moved your second message into your older thread…
(3,910 Views)
