Daq Assistant does not bring up dialog box
I have been trying to open a new Daq Assistant in a .VI on my LabView 8.2.1 on my laptop. I can select it and place it in my wiring diagram, but it will not automatically open for me to configure channels, max/min values, wiring configurations, etc. I try to right-click and select properties also, and nothing happens. What could I be doing wrong?
(3,430 Views)
Hi dglock18,
Which version of DAQmx do you have installed?
Josh B
(3,405 Views)
DAQmx version
@Joshua-B wrote:
Hi dglock18,
9.2.2 from what I can tell.
(3,398 Views)
Hi dglock18,
It doesn't appear that this version of DAQmx is compatible with this version of LabVIEW.  I've included a link below to a document that shows the compatibility between versions.
NI-DAQ and LabVIEW Version Compatibility (for Windows)
http://digital.ni.com/public.nsf/allkb/B0D5630C0A50D5C6862578E800459248?OpenDocument
Josh B
(3,388 Views)
Radhika_Unni_0-1575649421222.png My Version is apparently compatible, but it still does not open the Dialogue box
(2,798 Views)
