Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Daq-MX read for digital output
Nacree
Member
10-17-2006
03:50 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Why does the Daq-mx read.vi only output an array of 8 booleans when my task has 28 channels and therefore the array should have 28 booleans.
See picture
Nathan
New-3.jpg 501 KB
0
Kudos
Message
1
of 3
(2,733 Views)
Reply
Re: Daq-MX read for digital output
Dennis_Knutson
Knight of NI
10-17-2006
04:17 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Because the default for Array to Cluster is nine elements. If you count again, you will see that there are actually 9 and not 8. Right click on the Array to Cluster and select Cluster Size to change it.
0
Kudos
Message
2
of 3
(2,729 Views)
Reply
Nacree
Member
Author
10-17-2006
04:22 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Thank you very much.
Never knew the default cluster size was 9 elements (kind of a strange number, no?). Anyway, thanks very much for the help.
-Nathan
0
Kudos
Message
3
of 3
(2,725 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
