Daq Triggering after Fieldpoint Activation
Hi,hope someone can help.. i'm lost on this now..basically i want to do this:
activate fieldpoint to pump stepping current-starting from 0 mA(from 0-10mA in steps of 1mA) ==> after 0.5s ==> DAQ card is triggered and will record the reading ==> fieldpoint steps to 1mA ==> after 0.5s ==>DAQ triggered and record the readings ==> REPEAT till 10mA.
Is there any examples VIs or icons which will help me to acheive this?
Appreciate a lot for the help=D
Message Edited by SG_SP_OLED on 09-29-2006 02:20 AM
(2,993 Views)
Greetings!
     There is a shipping example in LabVIEW 8.2 with the latest fieldpoint drivers and the NI cFP-AO-200. Please refer to the attachment to the location in the example finder that you can find the example from. Also in DAQ to measure current, you will have use a resistor. Please refer to the link below -
http://zone.ni.com/reference/en-XX/help/371361B-01/lvmeasapps/measuring_current/
http://digital.ni.com/public.nsf/websearch/82508CD693197EA68625629700677B70?OpenDocument
http://digital.ni.com/public.nsf/websearch/29534F94B158054486256B490059E3AD?OpenDocument
http://digital.ni.com/public.nsf/websearch/4017793371AC28478625706800531CBE?OpenDocument
Thanks and hope this helps
Best regards
Avi Harjani
(2,976 Views)
