Daq assistant as input for formula
I need the output from my DAQ assistant to be the input in a formula node. But I can not do it since the terminals are different; dynamic data vs double [64-bit real (~15 digit precision)]. Is there a way in which I can use this dynamic data in a formula node?
(3,564 Views)
Accepted by topic author Allard171
Look in the express palette under signal manipulation for another express VI called "From DDT".
(3,562 Views)
