Daq output as switches
I am using a 9435 Digital input DAQ card to acquire digital signals from 2 IR sensors, and have given two channels in the config menu of the daq assistant. How do i get two seperate digital outputs from the DAQ assistant that can serve as switches to leds?
PS: I am a beginner in labview
(2,704 Views)
You are reading both channels with the DAQ Assistant?  Then use the From Dynamic Data Type to change to an array of digital waveforms and then use Index Array.
Since you are a beginner, might I suggest some tutorials?
3 Hour Introduction
6 Hour Introduction
LabVEW Basics
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
LabVIEW Wiki on Training
Learning NI
Getting Started with NI Products
GCentral
(2,670 Views)
Thank you 🙂
(2,651 Views)
