Daq output
i am working to generate digital pulse pattern based on user input . I have created a single task for 3 channels.  i needed to create 3 independent boolean switch for turn off each channels and set the state to low after turn off. the program has a boolean switch for continous output and finite output. the turn off works fine for the continous output but not for the finite.
Tasks
create the channels as 3 tasks and 3 independent switches for controlling them.
regards,
Message 1 of 1
(1,164 Views)
