DaqMX timing with DI and DO tasks
I have a question about applying sample clocks to multiple tasks, as I keep getting errors. I know this is a fundamental issue that I am misunderstanding, so I appreciate everyone's help and suggestions.
I am using multiple CDaq chasis with multiple AI, Thermocouple and DIO modules.
I have created 4 tasks:
1 for all AI
1 for all TC
1 for all DI
1 for all DO
When I run the code pictured above, it works. When I try to apply timing to the DI and DO modules, though, I get an error that the hardware conflicts. I applied continuous samples with the same rate that is wired into the AI and TC tasks.
I've researched into the issue and tried some of the examples, but I am still a bit baffled.
I want to avoid having an uncontrolled data rate from my DI and DO modules which could overwhelm the system.
How can I assign timing to those tasks?
Also, should I fundamentally change the framework I am using for the tasks?
Thanks for all the help.
Message 1 of 18
(1,601 Views)
What cDAQ chassis do you use?
https://www.ni.com/en/support/documentation/supplemental/18/number-of-concurrent-tasks-on-a-compactd...
Have you tried a very basic example that generate/acquire hardware timed task per type (AI, AO, DI, DO) for all types?
Santhosh
Soliton Technologies
Message 2 of 18
(1,577 Views)
Hi -
I appreciate your help!
It is a cDaq 9189.
Hardware Timed Tasks
# of Tasks per Chassis
# of Tasks per Module
Analog Input
3*
1
Analog Output
1
1
Counter Input/Output
4, 6
4, 1
Digital Input
1
1
Digital Output
1
1
I am using 2 chasis's.
I am trying to use 2 DIO modules (both are 9403).
Both of these modules are on the same chasis.
Should I change the timing source on the sample time settings?
I tried that a bit but still got the error - but maybe I missed something.
Message 3 of 18
(1,570 Views)
Hi GOB,
The table shows "1 DI task per chassis" and "1 DO task per chassis".
And it says "only one DI/DO task per module".
Those are the rules.
Unfortunately all the details of your implementation is hidden in a subVI - and you don't provide information on that subVI…
Message 4 of 18
(1,535 Views)
Thanks for the reply @GerdW.
 I understand the limitation noted in the table, the thing is it works when I don’t include the timing for the DI and DO tasks - so i don’t see how it is an issue with number of tasks but more I am messing up some timing setting.
If I don’t specify the timing for a DI or DO module, and I am using a producer/consumer QMH structure like the “continuous measurement and logging(daqmx)” template, then what rate is it running at?
Regarding any sub VI - there is nothing else going on besides the tasks get initiated (with false and then the task references brought in here.
Appreciate the help!
Message 5 of 18
(1,528 Views)
Hi GOB,
The timing engine is the limiting part in here: this engine only supports a limited number of tasks…
It will run at the rate of the measurement/producer loop: when you don't set a timing in the DAQmx task then you should set a timing in your producer loop…
Message 6 of 18
(1,523 Views)
Could I make the DI and DO one task?
Message 7 of 18
(1,506 Views)
Hi GOB,
How would you distinguish between inputs and outputs when using DAQmxRead/DAQmxWrite on your task?
No, you cannot mix inputs and outputs within one task…
Message 8 of 18
(1,504 Views)
OK, so in the future with this hardware, I will need to separate DI and DO onto different modules in order to get hardware timing. I can't do that for my current project.
That is somewhat limiting and frustrating but I understand now!
Also annoying because it effects the rest of the system timing wise -
i.e. I am acquiring from all tasks in the same loop - all the other input modules have timing set via hardware.
Now I have this "rogue" other DI module that does not have hardware timing possible. So I have to introduce a wait because of that module.
Message 9 of 18
(1,482 Views)
Hi GOB,
@GOB34 wrote:
it effects the rest of the system timing wise - i.e. I am acquiring from all tasks in the same loop
NOBODY enforces you to put all DAQmx code into just one loop!
I usually use one loop per task…
Message 10 of 18
(1,474 Views)
