Daqmx Create Timing Souce vi with Timed loop
Hello all,
I'am tryng to control the ticking of a timed loop based on an external trigger signal that appears on the PFI line of a PXI 6280 card. I want the timed loop to execute the code within it whenever a rising edge appears on the PFI line. My block diagram is as shown below.
Here, i will be selecting the PFI line for the "rising edge physical channels" terminal. I dont need any "falling edge physical channels" , so can i just leave that terminal unwired. If so , does the code work as intended?
Best Regards
Deepu Jacob
Waiting For the inner calling 🙂
Message 1 of 1
(3,103 Views)
