‎12-21-2009 11:58 AM
I haven't fired up labview in about two months and no have a strange problem. I am trying to setup a new module to acquire thermocouple and RTD inputs. It is a 9213 chassis. When I place the DAQ assitant down and setup the signals in the wizard I never get the "data" stream on my icon. This is the part where you wire it to get the data out. I am sure I am missing something brutally simple but I can't figure it out.
Solved! Go to Solution.
‎12-21-2009 12:09 PM
Icemaker,
This very thing happened to me last friday. I was trying to answer somebodys post here and went to use the DAQ assistant. I don't use the express vis because I find them restrictive. I played and played until I finally figured out that when configuring the assistant you must click the 'ok' button on the bottom of the DAQ configuration wizard. In my case this was hidden below my screen. When I moved the window up I found it.
Hope this helps in your case.
‎12-21-2009 12:19 PM
‎12-21-2009 12:28 PM
‎12-21-2009 01:28 PM
‎12-21-2009 02:05 PM
‎12-22-2009
10:12 AM
- last edited on
‎07-29-2026
12:42 PM
by
Content Cleaner
Hi Icemaker,
If you have pressed the OK button in the DAQ Assistant and you still do not have any inputs or outputs, you should try repairing your DAQmx driver. Please see the attached document for steps to uninstall or repair software.
‎12-22-2009 01:44 PM
‎12-29-2009 12:30 PM
‎12-30-2009
10:08 AM
- last edited on
‎07-29-2026
12:42 PM
by
Content Cleaner
Hi icemaker,
This points to the DAQ Assistant being corrupt. What version of DAQmx are you using? Have you tried updating to the latest version of the driver? You can find these online at the link below.
