Daqmx
 When measuring a physical signal using LabVIEW and NI hardware, what is the correct path of the signal?
  1. Sensor>Terminal Block>DAQ>LabVIEW
  2. DAQ>Sensor>Terminal Block>LabVIEW
  3. Terminal Block>LabVIEW>Sensor>DAQ
  4. Sensor>DAQ>Terminal Block>LabVIEW
(1,561 Views)
Why don't you talk to your fellow students?  I can't say that I understand the question, but I'll try to help you a little -- do a Web search for "Learn 10 Functions in NI-DAQmx and Handle 80% of your Data Acquisition Applications" (or, alternatively, load one of the many DAQmx examples that ship with LabVIEW) and look at the order of the functions and their relative positions on the (common) Error Wire.
What does your instructor mean by "Sensor", "Terminal Block", "DAQ", and "LabVIEW"?
Bob Schor
(1,523 Views)
Yeah the question was little un understandable.. then the daqmx alignment will be as the virtual, sample clock, start, Read/write, stop ... But here the questions they said that
Which is the correct order for the signal to propagate through components when acquiring a signal?
A. Sensor>Terminal Block>DAQ>LabVIEW
B. DAQ>Sensor>Terminal Block>LabVIEW
C. Terminal Block>LabVIEW>Sensor>DAQ
D. Sensor>DAQ>Terminal Block>LabVIEW
In those options I have an dout in terminal block in my point of view my allignment will be
Sensors, daq, terminal block, Labview
But some frnds say that
Sensors, terminal blocks,daq, labview
What will be the correct one in those...
Thank you...
(1,505 Views)
As I said, I don't know what your instructor meant by the terms "sensor", "terminal block", "DAQ", or "LabVIEW".  But I also pointed you to examples of LabVIEW code showing the use of LabVIEW code to do data acquisition (or data generation) -- all you need to do is look at "known good LabVIEW code" and figure out how to "order" the four terms, which were (presumably) defined by your instructor.  So you'll have to do the work of learning what your instructor means by these terms, and then look at the LabVIEW examples and figure out how to sequence them.
Bob Schor
(1,494 Views)
Accepted by Petru_Tarabuta
Thank you...
Option A: Sensor -> Terminal Block -> DAQ -> LabVIEW
Sensors generate the electrical signal
Terminal block (implicitly screw terminals) connects external signal wires into DAQ
DAQ is the hardware that converts the electrical signal into digital data
LabVIEW is the software that runs the data acquisition logic to acquire data from DAQ
Santhosh
Soliton Technologies
(1,480 Views)
Thank you...
Yeah information is so usefull...
(1,472 Views)
When i read Santos answer i understood the question ...
Qestit Systems
Certified-LabVIEW-Developer
(932 Views)
