04-12-2019 03:52 PM
You probably know that you can right-click a wire and select "Clean Up Wire":
This is handy, but (1) it requires you to navigate a menu, and (2) it doesn't support multi-select.
Did you know that you can select a wire and press Ctrl-U to do the same thing? Or that you can select multiple wires and press Ctrl-U to clean them all up?
04-12-2019 04:06 PM
That's a long stretch even for my big hands. ![]()
Also Ctrl+B removes all broken wires.
04-12-2019 05:20 PM
All my wires are laid down neatly from the beginning, so I have no need for any of this. 😄
04-12-2019 10:17 PM
I'm midway between Darren and Christian -- I try to lay down straight wires, but I didn't know the ^U trick, and will try it out (as sometimes wires get a one-pixel "kink" ...) (and occasionally much worse, I'm ashamed to admit).
Bob Schor
04-13-2019 07:08 AM
Thanks Darren for the Nugget Ctrl-U.
04-13-2019 10:29 AM - edited 04-13-2019 10:43 AM
One of those reasons I want the default setting changed for the block diagram grid spacing too match the shift arrow. How nice would it be to have shift arrow move things 4, 5, 8, 12, whatever number of pixels you choose
Hey, see the IEJeff is smart
04-13-2019 01:19 PM
I am not sure what you mean by "shift arrow" and where would you chose the distance?
In general, <shift>+arrow aligns with the nearest grid line in that direction, i e. the shift distance depends on how far away the nearest grid line is (jump is anywhere between 1 and grid spacing. If we are already aligned with the grid, <shift>+arrow will move exactly by the grid spacing).
I sort of got used to that. So you want <shift>+arrow to move a constant distance, retaining the existing grid misalignment?
04-13-2019 01:31 PM - edited 04-13-2019 01:40 PM
Shift + an Arrow key ( up, down, left, right) moves selected things by 4 pixels on the block diagram. On a front panel, it moves to the nearest grid space or a whole grid space up to 5 pixels. ...silly strange behavior that should be looked at.
And, select from tools>>options. Or VI properties grid spacing. By vi or default for new vis, (vi, ctl,vit, vim, ctt, ctm,. Etc)
04-13-2019 01:47 PM
Ah, emphasis on "block diagram".
04-13-2019 04:57 PM
@altenbach wrote:
@JÞB wrote:
Shift + an Arrow key ( up, down, left, right) moves selected things by 4 pixels on the block diagram.Ah, emphasis on "block diagram".
As I said, silly, strange behavior
