Darren's Occasional Nugget 07/17/2014
Today's nugget has to do with Intensity Graphs and Intensity Charts. By default, they have a blue color map for the Z scale:
If you want to reconfigure the colors, you can right-click any of the numbers in the Z scale and choose Marker Color. It is also possible to programmatically manipulate the scale with the Color Table property of the Intensity Graph/Chart.
I have attached a VI below called Intensity Color Tables.vi that allows you to select between several pre-defined color maps for your Intensity Graphs and Charts. The VI generates the Color Table array that can be wired to the Color Table property. I think my favorite color map is "fire":
Check out the demo VI (in LabVIEW 2009 or later) to see the Intensity Color Tables.vi in action.
(10,831 Views)
Awesome, thank you for posting!!
Rahul B.
(10,622 Views)
And this shipping example shows an practical usage of this feature:
C:\Program Files (x86)\National Instruments\LabVIEW 2013\examples\Signal Processing\Transforms\STFT Spectrogram Demo.vi
Barp - Control, Simulation, RTT and HIL - National Instruments
(10,539 Views)
I did something similar for a project I was working on
Randall Pursley
(6,885 Views)
(I know, old thread...)
I often work with greyscale image data and all I ever need to do is remove the middle marker from the default Z axis (and change the upper limit to 255). Poof, the blue disappears and all that's left is a linear gray scale!
(846 Views)
