Darren's Occasional Nugget 08/14/2014
This is one of those "how in the world did I not know this?" nuggets. During a code review yesterday, one of my colleagues asked me to make an LED bigger on the panel of a VI. After my resize attempt, the LED was oval-shaped, to which my colleague remarked, "You know, you can shift-drag to resize objects proportionally in both directions".
How cool is that? From what I can tell, you can do a shift-drag-resize on any object that can resize in multiple directions, including objects on the block diagram. Remember this nugget whenever you're resizing an object and you want it to keep the original height/width ratio at its new size.
Message 1 of 25
(10,496 Views)
This mouse-key combination seems to be some kind of a standard.  It works in some other applications as well.
Message 2 of 25
(10,462 Views)
Ctrl-drag-resizing is also very useful, keeps the center position.
Shift-Ctrl-drag resizing keeps it centered and circular.
Message 3 of 25
(10,453 Views)
Why isn't this sort of thing DOCUMENTED!  Surely I should be able to find these shortcuts without having to read a blog.  BUT THANKS FOR THE TIP!!
Message 4 of 25
(10,443 Views)
http://www.ni.com/pdf/manuals/373353c.pdf
They seem to have stopped shipping this with LV, much more useful IMO than the stickers....
Message 5 of 25
(10,426 Views)
Well, depending on where you look, it is documented.
LabVIEW WIKI - Keyboard shortcuts
Message 6 of 25
(10,416 Views)
Not a NI web site. But thanks for the link!
Message 7 of 25
(10,375 Views)
The shift-resize thing is fairly standard in graphics editors.  Some keep proportions, others snap to square (0/45/90 for lines/squres/etc in the tools I use) with that modifier key.
Knew about the shift-key thing, but I like the ctrl-shift thing.  I can see myself using that a lot. Smiley Wink
Message 8 of 25
(10,368 Views)
AWESOME!
Steven Howell
Certified LabVIEW Developer
Systems Developer
Optimation - Houston
steven.howell@optimation.us
Message 9 of 25
(10,277 Views)
For those who use Vision Development Module, there's a similar trick for resizing a region of interest.
For instance, when moving a rotated rectangle, holding SHIFT snnaps to modulo 45° angles.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 10 of 25
(10,233 Views)
