Darren's Weekly Nugget 02/20/2006
Most of the LabVIEW veterans probably know this one, but for anybody who doesn't, this nugget is about to make your day.  If you want to scroll the frames of a Case Structure, usually you click the left/right arrows in the selector at the top, or you click the down arrow to get a list of cases so you can select one.  Well check this out...you can also scroll the cases of your Case Structure with your mouse scroll wheel!  Just put your mouse cursor in an empty space of the Case Structure diagram, hold down the Ctrl key, and start scrolling the different case diagrams with your mouse wheel!  I found this one out a few years ago, and it still remains one of my top "holy crap, that is so cool!" LabVIEW features...I use it dozens of times every day.  This trick also works on other multi-frame structures, like Event Structures.  It also works on Stacked Sequence Structures (but you shouldn't be using those anyway...) 😉
-D
Message Edited by Support on 02-28-2006 10:59 AM
Message 1 of 22
(14,597 Views)
 hey I knew that one, does it mean I can be concidered as a LabVIEW veteran Smiley Surprised
Indeed you've made my day Darren, it's cool to feel clever 😄
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 2 of 22
(14,574 Views)
I keep managing to forget that one. I hope this time it will stick.
___________________
Try to take over the world!
Message 3 of 22
(14,557 Views)
Darren,
On the Mac (OS X 10.4.5) it does not work at all in LV7.1.1 and in LV8 it requires the Cmd button, not Control. Which is somewhat wierd, because most apps on the Mac use the Cmd key for context sensitive clicks, but LV8 now requires Control. Very hard to change habits for one application.
Lynn
Message 4 of 22
(14,558 Views)
Sorry Lynn, can't say I try all of these out on all platforms before posting them.  😉  Should I start calling them Windows McNuggets instead?
-D
Message 5 of 22
(14,553 Views)
Darren,
No need. I appreciate your efforts to provide the Nuggets (whatever flavor). I was just letting other Mac users know that this one was somewhat platform dependent.
Lynn
Message 6 of 22
(14,541 Views)
Are past nuggets archived online somewhere?
Chuck
Message 7 of 22
(14,472 Views)
http://forums.ni.com/ni/board/message?board.id=BreakPoint&message.id=1669
they are maybe not all in that thread but it's a bit like a review, I you want to get all of them just do a search with "weekly nugget" 😉
Epictetus
Antoine Chalons
Message 8 of 22
(14,467 Views)
As I said, Darren, you should probably add the link to the BP thread to your signature, or people are likely to keep asking this question.
___________________
Message 9 of 22
(14,456 Views)
Ok fine, I'll start posting the link to the Breakpoint thread at the end of each nugget every week.  But that's as far as I'll go.  No signature.  The Nugget Master has spoken.
-D
Message 10 of 22
(14,446 Views)
