Darren's Weekly Nugget 04/17/2006
In LabVIEW 8.0, you can make your VI front panels partially transparent while the VI is running.  This can be handy when you have a "floating" front panel window that you want to be always available in your app, but perhaps you still want to have a global view of all the contents of your desktop.  To play with this setting, check out VI Properties > Window Appearance > Customize... > Window Runs Transparent.  You can also set the transparency level to a value between 0% and 100%.
-D
P.S. - Check out past nuggets here.
(15,879 Views)
For those without 8 (but with windows), this is achieved through windows API functions as demonstarted in the attached VI (which includes a VI from the winutil library). The connector pane and FP are not properly set up, but it shows the concept.
___________________
Try to take over the world!
(15,856 Views)
One reminder,
if you set transparency to 0% BUT not mark you're VI as non-transparent it will cost you a lot of resources...
Ton
My LabVIEW Ideas
(15,719 Views)
Can you do this programatically?
(15,634 Views)
I'm pretty sure that I remember this being available either as a property or as a method (probably a property) of either the VI or the front panel.
___________________
(15,618 Views)
I was just about to reply to myself.  There is actually an example under the "new in 8.0" examples.  It is a property, and rather quite easy.
Thanks.
(15,610 Views)
