Darren's Weekly Nugget 09/21/2009
@Darren wrote:
Hooovahh wrote:
I think it should be mentioned that this will not work under all circumstances.  If you have two versions of LabVIEW open (say you opened 8.0 then 8.5) and you right click the file send to LabVIEW 8.0, it will open it with LabVIEW 8.5.
I'm not sure if it's because I'm running Windows 7, but I can't reproduce this.  No matter what version(s) of LabVIEW I already have running, or which one I ran last, the correct version always opens the VI if I right-click and Send To.
Hi Darren
I run Windows Vista and I have the same behavior as Hooovahh when LabVIEW 8.6 and 2009 are bought open.
Your idea with the send to menu could be extended with this idea.
Greetings,
shb
Message 11 of 11
(565 Views)
