Darren's Weekly Nugget 10/05/2009
Now that VI Scripting is available, I thought it would be handy to write a nugget about the VariantDataType VIs.  In LabVIEW 8.0 and later, there is a set of VIs in vi.lib/utility/VariantDataType that are immensely helpful when writing code that involves parsing LabVIEW data types.  There's too much in there for me to describe in a single nugget, so I encourage you to explore the VIs, and keep in mind these tips:
  • You will usually use these VIs in conjunction with the Data Type property of the Terminal class.  GetTypeInfo.vi is the best place to get started, as it is the VI that will return an enum describing the data type you wired in to the VI.
  • A few of the data types listed in the type enum used by these VIs are internal LabVIEW types that you should never encounter in a VI diagram.
  • The more recent your LabVIEW version, the more useful stuff you'll find in the VariantDataType folder (like the Check for Contained Data Type.vi I added in LabVIEW 8.6).
  • If you are using LabVIEW 7.x, a similar set of utilities resides in vi.lib/utility/GetType.llb.  These VIs parse I16 array type descriptors, which were deprecated in LabVIEW 8.0 in favor of Variant-based type descriptors.
Most of the VIs in this folder have Context Help that describe their functionality.  The "Get" VIs are probably going to be the most helpful for you since they are useful for obtaining information about existing data types.  There are also some "Set" VIs that might be useful for more advanced applications that involve changing certain characteristics of certain data types.
(9,904 Views)
Nice tip. I've already used started using the "GetNumericInfo" VI  because of this tip.
CLED (2016)
(9,875 Views)
I am sorry but I cant't access you blog(http://labviewartisan.blogspot.com/.
(9,832 Views)
I'm not sure why...I think some employers block access to certain domains...blogspot.com might be one of them?
(9,745 Views)
Very much, yes! Smiley Mad
- Partha ( CLD until Oct 2027 🙂 )
(9,669 Views)
I started playing around with these in LV 7.1, very useful so far (I want to convert a cluster to a spreadsheet string).
I found some 'bug':
When I use a timestamp, it say 'Waveform (Measurement Data)', the same goes for Analog Waveform (as expected).
Is this still the case for 2009?
Felix
(9,645 Views)
F. Schubert wrote:
I found some 'bug':
In LabVIEW 7.x, the Measure Data (waveform) type includes both waveforms and timestamps.  In LabVIEW 8.0 and later, there are different entries in the enum for them:  Waveform and Timestamp.
(9,599 Views)
