Darren's Weekly Nugget 11/20/2006
@Darren wrote:
The number of elements in the array that is wired to the Array to Cluster function is dynamic, i.e. it could be anything at run-time.  Since the elements in a cluster are a part of its data type, and LabVIEW is a strictly-typed language, LabVIEW cannot compile a VI that contains a cluster with an unknown number of elements.  Thus, you must statically define the number of elements in the generated cluster at edit time.
And yes, we are aware of the difficulties regarding functions with these "hidden" configuration options, and we're looking into ways of addressing this issue in a future LabVIEW version.
-D
The Array to Cluster node should, IMO, have an optional "type" input that allows setting the output cluster type and, therefore, size.  One of the most common patterns for using the Array to Cluster node is when one is iterating over the elements of a cluster, by first converting it to an array using the Cluster to Array node, which means that you have the original cluster type readily available.
In fact, this technique is possible with arbitrary clusters using the OpenG Variant tools (lvdata library): convert the cluster to an array of variants, iterate over the array, and convert the array of variants back into a cluster.
Message Edited by Jim Kring on 11-23-2006 10:20 AM
Message 11 of 21
(5,833 Views)
Jim,
You mean like this (actual code)
Shane.
Message Edited by shoneill on 11-24-2006 08:17 AM
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
Message 12 of 21
(5,698 Views)
Hi all,
Just one thing I noticed about the "array to cluster" function, the maximum size that can be set is 256 but what surprised me is that 0 can be set Smiley Surprised but if 0 is set it will actually operate like if 1 was set...
Weird, no ?
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 13 of 21
(5,633 Views)
I just found this (with TiTou's help).
Associate text with a wire.
See this thread to learn how.
Ben
Message 14 of 21
(5,538 Views)
With my help Smiley Surprised
That's too much honor... Basically I said "you can't do this" and there you came with the trick.
Your hate of "you can't do this"-replies is the one to be honored 😉
I once read this sentence (don't remember who it is from) "We are not limited by the vast domain of the possible, but by the space inside us"
Epictetus
Antoine Chalons
Message 15 of 21
(5,534 Views)
Love your come-back Shane. Smiley Very Happy
Since many of us are putting together the same constructs (cluster to array ...) so we can iterate through a cluster....
How would Y'all feel about adding the ability to directly index through a cluster on the edge of a For or While loop?
Is this a good idea or a bad one?
Your thoughts?
Ben
Message 16 of 21
(5,536 Views)
@shoneill wrote:
Jim,
Shane.
Hi Shane,
The Type Cast function is a good solution for clusters of fixed-width clusters (i.e., brown-wired clusters), with elements of numerics, booleans, etc.  However, it won't work on variable-widthed clusters (i.e., pink-wired clusters), with elements of strings, arrays, etc.
Cheers,
Message Edited by Jim Kring on 11-24-2006 12:10 PM
Message 17 of 21
(5,490 Views)
The Cluster-to-Array function itself won't accept the cluster containing the variable-length data-types (arrays).
Message Edited by pauldavey on 11-27-2006 05:23 PM
Message 18 of 21
(5,035 Views)
The Cluster-to-array function may not take clusters of arrays, but it DOES take clusters of strings, which are variable length.
I find the inability of LV to accept a cluster of strings as datatype (For the Type cast function) a limitation which should be corrected.
Is there a reason wha this shouldn't work?  LV doesn't use terminated stringa AFAIK, but shouldn't it be possible to work out how long the string is from the flattened data (1st 4 Bytes = String length)?
Shane.
Message Edited by shoneill on 11-27-2006 01:04 PM
Message 19 of 21
(5,021 Views)
Just a quick note: I was in on a couple prior discussions about converting cluster-to-array, performing array-based processing, then converting array-to-cluster again.  The first one is here.  The second one got a "blue bar" response from someone internal to NI.   That one's here.  Not sure I'm adding much to this thread here so I'll be going now...
-Kevin P.
Message 20 of 21
(4,939 Views)
