Dashed line on a XY graph
I am not able to select the dashed line from Lyne Style. LV 2015 SP1 32 bit doesn't allow me to do that. Is It a bug? Have you any suggestion to force LV to accept to make a plot with the dashed line selected?
Message 1 of 12
(4,558 Views)
Attach your code (include the entire VI as an attached file) so we can figure out what you may be doing wrong.
Bob Schor
Message 2 of 12
(4,520 Views)
This is an example (made with LV 2015 SP1 64 bit on another pc).
I would like the white line as solid, the red line as dashed, the green line as dotted.
If I seect the dashed line, it is automatically switched to dotted when I run the vi.
Message 3 of 12
(4,484 Views)
Very weird... I cannot get dashed and dotted lines on the same graph. All the dashed lines turn into dotted (or small dash) lines when the VI is run, or when the legend is expanded. Even after creating a new XY Graph the same behavior occurs.
Message 4 of 12
(4,478 Views)
Is It possible to tell about It to the developers?
Message 5 of 12
(4,474 Views)
I'm not sure, but your posted code worked just fine for me when I ran it in LabVIEW 2016 (32-bit) on Windows 7 x64.  Here's what I did --
  • Ran your VI.
  • Modified the plots so the Red Plot was Dashed (I made the line a little thicker for visibility) and the Green Plot was Dotted (also thicker).
  • Ran the VI several times again, verified that the line attributes "stuck".
Here's what it looks like:
I also have attached my VI (again, LabVIEW 2016).
Bob Schor
Message 6 of 12
(4,462 Views)
Interesting... Bob's VI "sticks" for me as well!
Message 7 of 12
(4,460 Views)
it ok i think!!!
Message 8 of 12
(4,449 Views)
Untitled.pngit working
Message 9 of 12
(4,448 Views)
Asif, your Red and Green plots use the same line style.  The OP wanted three different line styles, specifically Dashed and Dotted ...
BS
Message 10 of 12
(4,442 Views)
