Data Acquisition and Processing
how do I record current through a LED and applying fft on it. I am using cRIO 9082 and Daq is NI9227 and LabVIEW 2015.
(2,848 Views)
Hi dcrustee,
first you should measure the current using the 9227 module, then you need to apply a FFT on those measurement data!
What have you tried so far? Where are you stuck?
Did you take the Getting Started courses offered on top of the LabVIEW forum?
(2,832 Views)
