Data Acquisition between NI 9263 and NI 9205
I've configured the 9263 to output directly into the 9205.  See the attached VI for how it was done.
Message 11 of 12
(574 Views)
Hello braxtonlewis,
The reason you were getting the error is because your DAQ Assistant is looking for an array of data since you configured for two channels. Build an array of the voltage values you wish to configure your 2 channels and the error should disappear, per attached image.
Glenn
Message 12 of 12
(547 Views)
