Data Acquisition frequence
I am trying to save the data I acquired to a TDMS file and then use FTP to send it to my computer. The problem I am facing is that the data acquisition frequency can only go up to 500 Hz. When I try to change the loop frequency to 1 kHz, for example, it becomes unstable. I am using a cRIO 9094.
(671 Views)
Hi CV,
Then you did something wrong in your VI.
As you don't attach your VI you need to debug on your own!
Btw. there is no cRIO9094…
(666 Views)
Thank you for your response. Here is the VI I am using.
I am using the CRIO 9049.
(650 Views)
Hi CV,
Where exactly?
(636 Views)
