Data Acquisition rate is not as expected. Only half of the data were logged.
@Billy90 wrote:
Dear @GREK5000,
Hello! Thanks a lot for your help. I tried it today and it has some problems.
The data were too much. It exceeded the maximum data acquisition rate of the DAQ card I use.
I just sent you a message. Hope you receive my message.
About the test files, I don't think I am able to attached those files here 'cause those files are too large. Therefore, I will attach a screen shots of the txt file.
Thank you for your help!
Can't wait to hear from you.
Billy
I have not looked at your code, but using local variables is NOT the way to get all of the data. It is a good way to miss data. It sounds like you're on the right track with a producer/consumer architecture. Just a few tweeks as suggested and you should be able to record your data without issue and without data loss.
Message 11 of 12
(490 Views)
Hi GRCK5000
Yes, I agree too much is better. However the logging rate exceeds the maximum acquisition rate of the DAQ card which makes the results unreliable.
Since the sample rate is 25000. I am expecting 20*25000=500,000 data in 20 seconds. I’ll try the code you attached and let you know the results! Thanks!
Billy
Message 12 of 12
(478 Views)
