Data Acquistion Freezes second loop
I am trying to run two loops in parallel. One loop using a state machine for user interface and data acquistion and the second loop running a rs-485 update. The problem I am having is that I need to aquire data for ten seconds at a time and still read the serial port at least once every two seconds to prevent a watchdog from timing out. I am sure there is a better technique for doing this. The problem is that everytime I do a daq read the second loop freezes for ten seconds and times out the watchdog. Please Help!!!!
(2,791 Views)
My suggestion would be to use DAQ Occurrences. There is an example that comes with LabVIEW that shows how to do this. It can be found under Help >> Examples >> I/O Interfaces >> Data Acquisition >> Analog Input >> DAQ Occurrences. Using occurrences will temporarily put DAQ to 'sleep' until the DAQ buffer fills up. This will allow LabVIEW to continue processing the other Loop.
Chris_Mitchell
Product Development Engineer
Certified LabVIEW Architect
(2,791 Views)
