Data Dropout Cured by LabView Restart
Our Test Lab has a SCXI-1000 with 3 SCXI-1303 cards reading pressure and temperature sensors.  Recently, we have seen an issue where all the temperatures and pressures are shifted to incorrect values during the same second.  Many of the NTC temperature sensors increased 40-60°F.  Many sensors that were not being used and were reading 0, started reading values.  Some other sensors that were reading values started reading 0.
We were able to correct the problem by simply closing LabView and opening it again.  Has anyone seen this issue before and determined a cause?
(2,645 Views)
Likely some cabling was disturbed when someone walked by.
Santhosh
Soliton Technologies
(2,621 Views)
Can you post any of the actual code that does the data gathering?
How long does it take for this to happen (minutes, hours, days)?  Is it consistent or does it happen after a random amount of time each time?
If it's not a physical problem (i.e. cable bumped or whatever) then it could be some sort of internal buffer/counter/register that fills up over time.
Did it just happen the one time or is it a repeatable problem?
(2,618 Views)
It has happened twice in the past few weeks, both times when recording data.  Previously, it was running for around 7 years without seeing this issue.  When we see the issue we were able to correct the issue by restarting the LabView program.
There is quite a bit of code involved in the logging, but it looks like it is all put into a Build Array and sent to a Array To Spreadsheet String.  The error is occurring before the file is written.
Thanks for the clue on the buffer/counter/register!  We did get a new technician and I wonder if he is logging for a longer duration than the previous one.
(2,604 Views)
This sounds like you should be using a Producer/Consumer setup so that you can log the data as it comes in.  Otherwise, you might be running into a memory issue.
But your initial statement makes me think you do have an indexing issue.  We would need to see code to diagnose that any further.
(2,356 Views)
