Data Entry Resolution
I am working with a Numeric Control Properties (Data entry Tab) on the Front Panel Control (LabView 2010)
When I try to change the Increment, the field does not let me enter 0.00496324, it rounds it to 0.0050.
I tried to make changes to the Display Format Tab and tried different combinations of Ignore vs Coerce.
Any suggestions as to what I am doing wrong?
Message 1 of 13
(5,138 Views)
I'm not sure exactly what all you have tried yet, but here's what immediately comes to mind.
Data Entry tab:  Have the check "Use Default Limits" checked.  This is unless you actually need to limit the range.  Otherwise, make the increment VERY small (as in less than 10^-10).
Display Format:  Change the precision type to Digits of Precision and make the number of digits at least 8.
Message 2 of 13
(5,130 Views)
Does not work.
It rounds off to 4 digits, Also rounds off the Min and Max to 4 digits
Want: 0.005993
Get:   0.0060
Message 3 of 13
(5,120 Views)
Did you change the significant digits or digits of precision? You will need to change the number of precision.
Tim
GHSP
Message 4 of 13
(5,114 Views)
Here is a screen shot of the Format
Message 5 of 13
(5,110 Views)
The properties display has limited resolution. You can probably set the increment more accurately via a property node.
(This has been discussed before, let me try to find it...)
Message 6 of 13
(5,105 Views)
There's an idea to fix it. Were you thinking of that?
Message 7 of 13
(5,100 Views)
I can try it and see if it works. But it would seem to be an issue with NI. And if memory serves me, I was able to do this in the past. However, I do not believe that I went to this small of a resolution.
What is the mechanism for getting NI to look into it?
Thanks for everybodies help.
Message 8 of 13
(5,094 Views)
Ahhh, I totally misunderstood your problem.  Once again, a picture says 1000 words.
Message 9 of 13
(5,050 Views)
Now that we are on the same page.
Is there any solution or am I just asking LabView to do something that it can not do?
thanks
Message 10 of 13
(5,029 Views)
