Data Exporting from graph to excel
hi,
I am using LabVIEW 2011 and recently observed that i am unable to export the selected data on the LabVIEW chart to excel(which i used to do before). I stopped several services of LabVIEW in my PC few weeks back and  i suspected that this could be the reason for that. However after resuming all the NI services in task manager, still i am unable to do the same.
 if there is any missing piece of services/utilities in my PC which is causing this problem?
pls guide me on this.
Regards
llkavya
(2,002 Views)
Are you doing "right-click...export ...export data to excel"? (or something else)
What happens if you try? (right-click menu entry missing? Nothing?, etc.)
Do you have excel installed?
(1,978 Views)
Hi altenbach,
With Labview 2020 SP1 I have also been unable to right click and export graph data to excel. I used to be able to this before.  Excel does not open.  Previously, Excel would open open up with a lvtemporary 1234.* file.  That does not happen anymore. Perhaps I have inadvertently removed a pathname...
However, I am still able to rightclick and export to clipboard and then manually open an excel file and paste the data.  Could you kindly advise how to correct this please?  I suspect its something to do with configuration in labview.
Kind regards#
OxSanj
(1,849 Views)
