Data Flow without wire and simply my application
Hi;
I have wirtten a complicated vi in Labview. All I want to do is simplify the wire connections and use local variables instead of wires. Can I do that or is there another way so I can get rid of this wire mess?
I have tried the local variables option but it slowed my application down and at some point it does not work correctly so I think this is not a clever option.
Thank you.
(2,549 Views)
As far as possible, it is always better to streamline your dataflow with wiring, rather than using local variables.
It helps to follow a good design patters to make your vi compatible and more maintainable
Read this style guide to learn more
Message Edited by devchander on 10-18-2006 10:06 PM
(2,546 Views)
