Data Grid
Good Morning,
I have created a webvi that shows various information that i request from a database using the HTTP get function. i am wanting to now display all the data for a particular client on a webvi which would be in a table format. I am just struggling at the moment to get my data to gointo a data grid. at the moment i am calling for the data using a url which points to a php script on the server. From that i unflatten it using JSON. i them place that into a cluster property and then display each element on its own across the page. what i want to do now is show that data in a table format for lets say an engineer to look at. Please could someone point me in the right direction how i would go about doing that.
(2,462 Views)
Ultimately you need to convert JSON Data to Tree?
You can share the Data and Code you tried to help you in a better way.
You can Format the JSON (Cluster Data) to Tree by Parsing and Building Elements
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(2,460 Views)
