Data Logging in LabViEW
I created a program to acquire signals from sensors. but the only way to save those signals is when they have to be exported to excel file from waveform chart. The write measurement to file block is not saving the data. What is the solution?
(2,914 Views)
I'm sure that Write to Measurement File would be a valid solution, but you failed to attach your VI where you say it is not saving data.  If we see your code, then we can figure out what is going wrong.  When you show us nothing, we can make a million guesses as to what is wrong.
(2,897 Views)
I have attached the VI file here. Please have a look. Thank You.
(2,859 Views)
Is that your latest VI?
For the Write to Measurement File node to work, it actually needs to be placed in your VI!
(2,850 Views)
