Data Logging to Excel
Does anyone have an example?
I'm currently graphing voltage readings,
and would like to save the samples as I go.
The simpler the better.
TIA!
-Lisa
(3,272 Views)
Hi Lisa,
In your labview folder, under \examples\comm\ you can find ExcelExamples.llb containing main tasks VIs.
good luck ... and hope you have LV 6
(3,272 Views)
Use LabVIEW's own "Export Waveforms To Spreadsheet File.VI"
Is placed under "Waveform" - "Waveform File I/O" and is easy to use.
Best regards
Svend
"Lisa Lord" wrote in message
news:0D6406C312DFADE8.6AD69BEAE26219B6.1763F68627EB4491@lp.airnews.net...
> TIA!
> -Lisa
(3,272 Views)
Thanks folks,
I'll be working on it.
-Lisa
> Best regards
> Svend
> > TIA!
> > -Lisa
(3,272 Views)
