Data Plugin Matlab
Can anyone explain to me how to use the data plugin to write to mat files. I have tried to write some code so far to use it but i keep getting an error -2533 highlight that the node did not return a correct refnum. My code to open the database works fine but it will not let me to write to it. Just so everyone knowns I am writing to level 5 matlab file running Labview 64 bits 2013 edition. Also let me point out in the code attached the opening of the database is all preconfigured and works fine.
(5,306 Views)
Hi Anthonytec2,
I was able to find this forum post
https://forums.ni.com/t5/LabVIEW/Creating-mat-files-with-Matlab-dataplugin-in-LabVIEW/td-p/1678970
that provides an example of using the MAT data plugin to write to MAT files, hopefully this will be a good starting resource for you.
Otherwise it should be fairly simple to write these files with the read/write binary file functions. It seems that the MAT file format is well defined in this document:
https://www.mathworks.com/help/pdf_doc/matlab/matfile_format.pdf
so you should be able to write to it directly.
Additionally you may be able to use the MATI/O library to read and write to a MAT file.
http://sourceforge.net/projects/matio/
-Nate
Staff Certification Engineer
(5,264 Views)
