Data Storage in sbRIO
Hi Everyone,
                   I am trying to develop a real time data Application. In this application i am collecting the real time data from the Energy Meter, for this i am using the sbRIO 9601. I just want to save this data for 90 days in sbRIO memory or flush data in FIFO format after 90 days. So i need your help that what type of file format i use to store the data in sbRIO or why??
The frequency of receiving the data from the meter is less than 1 Sec....
the packet size of receiving the data is 140 bit/Sec....
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
(3,147 Views)
I am trying to do basically the same thing. I'm using 9602. I want to store the data from Inertial Measurement Unit during the test, which will last for less than an hour. Did you find the solution? Appreciate it.
Zhuoyuan
(2,736 Views)
