Data Structures in LabVIEW
Hello, I have a question that how could I convert a number from an arrary into an unsinged word?
Thank you.
(3,908 Views)
The problem here is that you are trying to connect an array of U16 to a terminal that wants a single U16. You either have to make your terminal accept an array, or put that function that requires a single element inside a for loop and auto-index the array into it..
CLD | CTD
(3,895 Views)
Hi arekguan,
when the source is an array and the sink requires a scalar value you should think of IndexArray (basic array function) or "loop with autoindexing" (basic LabVIEW structure).
As you asked for basic LabVIEW stuff: did you take the free online courses offered by NI on their website to learn LabVIEW?
(3,864 Views)
To avoid singing (that's "singe-ing", meaning "burning", not going "tra-la-la"), keep your VI away from matches!Smiley Wink
Bob Schor
(3,827 Views)
