Data Synchronisation between the devices
Hi bird,
   Actually  i should display 18 at trig time  ,i.e all the values should be synchronised ..
Thanks and regards,
srikrishnaNF
Srikrishna
Message 11 of 14
(1,119 Views)
How can they ALL be synchronized, if they occur at different times?
You're going to have to spend some words explaining your difficulty.
Steve Bird
Culverson.com
LinkedIn
Message 12 of 14
(1,116 Views)
HI bird,
   Actually the problem  is data is generating from device1 continuosly and markers are generating from device2 sometimes only. So say when markeri
generated at time 'to',so i should show the marker exactly at same time to of the continous data also in labview chart.For your reference i attached the chart plot also.Please note the time to should be the same.
Thanks and regards,
srikrishnaNF
Srikrishna
Message 13 of 14
(1,114 Views)
I'm still not understanding what you want.
In the list I gave above, when the trigger came in, the Dev1 value was "18".
So you have a data value synchronized with the trigger.
What else are you expecting?
Steve Bird
Culverson.com
LinkedIn
Message 14 of 14
(1,110 Views)
