Data Type Nonsense with xy plot
Hi everyone, this problem might be trivial to most of you, but I was just not able to solve it in any way shape or form... I consolidated with ChatGPT, it could not help me either.
I used LabVIEW to read from a .txt File and I extracted data I needed. My goal is to plot the data, but LabVIEW constantly complains that my "source" data type does not match the "sink" data type.
The "sink" is 1D Array of Cluster of 2 Elements. That is the exact data type of the "source", but LabVIEW complains nontheless. Both "phase angle" and "time" are 1x200 structures without any further unwanted input. I literally have no idea how to make this very simple request work.
Help is appreciated,
Thanks!
Message 1 of 8
(1,409 Views)
Addressing *only* the datatype issue...
The datatype of your source is *actually*: 1D Array of Cluster of 2 Arrays of N Elements
Supposing your 2 arrays have the same length, auto-index them through a For Loop where you build a cluster from individual array elements.  Then auto-index that cluster into an output 1D array.  See below:
-Kevin P
Message 2 of 8
(1,397 Views)
Hi KL/Kevin,
you can replace the FOR loop by Index&BundleClusterArray with 2 inputs…
Message 3 of 8
(1,361 Views)
There are so many things wrong with your code that I would recommend a few basic tutorials.*
You are NOT using an xy graph, but wire to the plotXY subVI which requires a picture indicator (missing!) as output and only accepts a single type of xy data (an array of points). I would strongly recommend to use an xy graph, which would accept your data (and much more!).
*footnote:
  • Do you really think it is reasonable to read the same file and do exactly the same processing millions of times per second (or until an array has the same size as the iteration count)?
  • Why read the same file twice in parallel and do some very convoluted duplicate processing to get the data jumping from array to string and back to array, etc.?
  • Can you attach a typical datafile and explain how the data is arranged and how you want to plot it?
  • I am sure the entire thing could be done with code that fits on a postage stamp!
  • Why is the phase angle derived from a timestamp while the time is just a DBL?
Message 4 of 8
(1,359 Views)
D'oh!   Good call.   (I forgot there even is such a function, I don't think I've ever used it.)
-Kevin P
Message 5 of 8
(1,320 Views)
I did not ask you to comment on the overall quality of my code. Please be professional
Message 6 of 8
(1,212 Views)
Hi KLS,
So we aren't professional because we comment on the quality of your code?
You're the one who wrote:
To become "more professional" you might think about:
  • attaching code instead of images of code. (We cannot debug/edit/run images in LabVIEW!)
  • use AutoCleanup as long as it improves your code. (Bugs can hide less in clean code!)
  • the meaning of "cluster of 2 elements", when "elements" aren't specified with more details.
Message 7 of 8
(1,204 Views)
It is not clear what post you are replying to, but if there is significant code stench, any "professional" will immediately see significantly more issues, and that just solving the "plot datatype" problem would just have you run into the next wall immediately.
Of course any advice here is completely free, has no guarantees, and can be ignored. No need to respond to it.
Message 8 of 8
(1,149 Views)
