Data acquisation from elvis board
help me, eight samples of dc voltage acquired from elvis board(not automatically, rather with eight runs. Now i want to use these in paralell , Kindly help me how to queue these eight samples
(3,199 Views)
Build Array?
Otherwise explain what you mean by "queue these 8 samples" and post a VI for what you have done so far.
(3,195 Views)
Dear Sir
Thanks for guiding me
In the vi there is eight bit array, i need that first sample value should go the first element of array, 2nd to 2nd and  so on  upto eight values. when all these are complete then next part of the system shis the first
(3,175 Views)
the last line
then the next part of the system should work
(3,170 Views)
(3,148 Views)
Accepted by topic author narula
thanks
(3,142 Views)
I'm glad it works for you then.
Please mark my post as the solution to your question rather than your thank you message.  You will first need to unmark your post as the solution by going to the options menu to the upper right of your message.
(3,139 Views)
