Data acquisition from SPCM-AQRH-15 and Nano-ViewTM 200-2/M
A good example to start with to use LabVIEW to do a digital output from the PCI-6602 can be found in Example Finder (found in LabVIEW under Help » Find Examples), where you would go to Hardware Input and Output » DAQmx » Digital Generation » Write Dig Chan.vi.
Kyle A.
Senior Applications Engineer
Message 11 of 12
(691 Views)
a technician has encouraged me to change the version of Vis that I use because I use an old Labview code with obsolete Vis. The new version of DAQ-mx works better, and is easyer to use. Thanks.
Message 12 of 12
(677 Views)
