Data acquisition from two different DAQs
Hello all,
Can you please tell me how to synchronous data acquisition using two different DAQs connected by USB to the computer in LabVIEW.
Thankyou for help.
Message 1 of 10
(5,439 Views)
What DAQs are you using?  Depending on the DAQ, you may be able to export and import the sample clock.  But we need more information to make sure.
Message 2 of 10
(5,405 Views)
Thank you for your reply,
I am using 2 NI C series DAQs which are connected to computer using 2 separate NI cDAQ chassis. How to synchronise both DAQs for data acquisition.
Message 3 of 10
(5,392 Views)
Again, WE NEED DETAILS.  What modules?  What chassis?
And why are you using multiple chassis?  I would just get a chassis that can hold both modules and then you just create a single task with all of the channels you need and the chassis will take care of everything for you there.
Message 4 of 10
(5,385 Views)
I would start with a trial:
One DAQmx task that incorporates the two modules (assuming that both are of the same kind, like two AI-modules).
Otherwise please be more specific: which c-modules, which cDAQ chassis, what would you like to synchronize?
Regards, Jens
Kudos are welcome...
Message 5 of 10
(5,383 Views)
I am using 2 NI cDAQ 9171 chassis and 2 C series 9215 modules.
How to sync these 2?
Message 6 of 10
(5,352 Views)
I am using 2 NI cDAQ 9171 chassis and 2 C series 9215 DAQs. How to sync these 2.
Message 7 of 10
(5,351 Views)
Accepted by topic author nagesh15
I'm not seeing anything from those to export/import a synchronization signal.  I would just invest in a cDAQ-9174 (4 slot USB cDAQ chassis), put both 9215 modules in it, and the rest is done for you as you will just need to create a single DAQmx task containing channels from both modules.
Message 8 of 10
(5,300 Views)
That means we can not sync both 9215 in 2 different chassis!
What if we want a different sampling rate and no. of samples for 9215 in 9174? Can we do that?
Message 9 of 10
(5,280 Views)
Not in two single chassis.
Yes, just define two independent AI tasks for the two 9215 modules.
Regards, Jens
Message 10 of 10
(5,277 Views)
