Data acquisition speed
I have PCI-6221 and controlling it with LabVIEW 8.2.1.  I am measuring a voltage with an express VI; I set the Acquisition mode to N Samples and 1000 samples at rate to 250kS/s.  I am only achieving a 163 S/s  rate.  Is there way to increase the sample rate?  Or am I just reading anaverage of values between each increment of time?  i.e. since the board is reading at 250kS/s and since I am reading at 163 I would be missing1533 samples.  Are my readings just an average of 1533 samples? If so how can I change it so I just read the value of the sample at that given time?  Also  I am  using a while loop; is there a better way to run a program to increase speed?  Finally, since the my daq board has a sampling rate of 250S/s does this limit the speed at which my computer exicutes programs?
Thank You
(2,717 Views)
You are going to have to post your code and also explain how you are determining that your sample rate of 163 S/s - or do your eally mean 163 kS/s?. Are you doing a single or multi-channel acquisition? Your reading will be 1000 samples no matter what the sample rate is.
(2,704 Views)
