Data acquisition status LED
Hi all, this should be a simple task that I am bang my head against.  I am using a USB-6215, grabbing 7 sec of data at a time.  I want a LED on the main VI to indicated when the acquisition is in progress.  I was heading toward a sequence structure controlling the LED before and after, but there must be a simpler way.
Any suggestions?
thanks
(2,640 Views)
Hi kman,
to get rid of the sequence structure you could use the error cluster to ensure dataflow. How much simpler do you need it?
(2,634 Views)
