Data acquisition using FPGA to read encoder through a bus using a pulse train that must pause with CLK+ set high
So I am trying to get data from an encoder using the SEA-9521 serial bus. I believe that I can get the loop correct on the timing  for the pulse train but one of the requirements to read data is that after a pulse train there needs to be a pause. While the pause is occouring the CLK+ must be set high for that time. I am not sure how to start the pause while the signal is at a high. I am using the Crio with FPGA on Labview 2018. If I could get any insight I would appreciate it.
(2,987 Views)
Can you post code?
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(2,956 Views)
Hello every one,
 Sorry for may message maybe it's not in the right discussion! but I need help if some one can figure out my problem.  I am new user of Labview, I use to use matlab and dSpace insteed.
I've got labviw 2012 ,I've also installed NIRIO120 for fpga drivers but I am still not able to see my chassis on my labview project (picture).
Could any one please help to resolve the problem and tell if I need to install something else ?
I am not connecting the labview to a real  RIO, I am just doing simulation on my computer.
Many thanks.
(2,934 Views)
