Data acquisition
I have bought a Kistler charge sensor with its amplifier. It has been delivred with a software using labview, but it does not work on my computer because it uses LabView 6.0 and I have the 7.1 on my computer.
I would like to know how to get data from the com1 port from my computer. The amplifier is plug on this port.
Thanks.
Benjamin.
(2,838 Views)
The conversion of 6.0 to 7.1 should be transparent and most VIs will run with no problem. What exactly doesn't work? To read or write data to a com port, you use the VISA Read/Write functions on the Instrument I/O>Serial palette. Make sure that VISA is installed on your system. If the 6.0 software used the old, obsolete serial functions, it's possible there is a problem with the conversion to VISA. You should also verify that you can talk to the instrument in a terminal emulator program such as Hyperterminal just to verify that you have the right cable and communication parameters set corretly.
(2,835 Views)
Ok, it does work.
Thanks for your help.
Benjamin.
(2,828 Views)
