Data acquisition
Hi!  at first, I want to thank every one who responded to my questions.
I'm actually using the evaluation version of LabVIEW 8.2 in window XP familiar edition.
I've installed NI-DAQmx 8.3 in odrer to learn how to acquire data.And since I don't have DAQ hardware, I decided to simulate DAQ device using MAX .But, the problem consists of the non- existence of the "Drivers and Interfaces" section in the configuration window.Is there any way to show all the sections of the configuration window of MAX.
(2,802 Views)
Are you still running off of what you installed off the evauation disk, or have you done like you were told to do in the other thread you started asking about this same issue and downloaded and installed the latest DAQmx drivers.
Don't start multiple threads about the same question.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,793 Views)
Hi Sihem,
I have responded to your post on your original thread.
Luke
(2,753 Views)
