Data acqusition with Labview using these specific cards
hi,
Well could you give me some guidelines how exactly should I proceed for calibration?????
In the task configuration page the input that I have set is -50m to +50m which is qlreqdy quite small.
The cut off frequency I hv set to 10Hz
Akash
Message 11 of 12
(406 Views)
Hi Akash Kumar,
To calibrate, I can do it in your task on MAX when you are configuring your task (illustration on the added file). I advise you to test your hardware by using an external signal generator on the input and see if you find the fluctuations you had before. If not , you should verify your sensor and his connections. If there is still fluctuations, you may have a hardware problem.
Jérémy M. | LinkedIn - Contact
Don't forget to give Kudos to good answers.
Message 12 of 12
(394 Views)
